Smartlight
Uses your smartlight to enhance your sleep experience
Features:
Sunrise-like wakeup
Pee-light
Jet lag prevention with light
Lucid dreaming and anti-snoring cues with light
Settings → Smartlight
3. Options
Use smartlight |
Enables smartlight support |
Maximum intensity |
Set a global limit for brightness a smartlight would be allowed to achieve when controlled by Sleep. This is useful for sunrise alarm where 100% might be too bright for some people. |
Sunrise |
Enable to use your phone’s screen as a smartlight for the sunrise alarm. |
Wake up with flashlight |
If enabled, your phone’s flashlight will be flashing during alarm.
Keep light up after |
Set whether the light should stay on after dismissing alarm, snoozing alarm or both. Or none. |
Pee-light |
If this is set, a pause in sleep tracking will turn on a red light on your set smartlight. If this is set to "Tracking is paused", the pee-light will be on for the whole pause. |
Lucid dreaming |
Use smartlight as a cue for lucid dreaming. When your REM phase is detected, your set light will flash. |
Anti-snoring |
Use smartlight as a cue for anti-snoring. When snoring is detected, your set light will flash. See |
Philips HUE, IKEA Trådfri (disconnected) |
Tap this to connect your HUE or Trådfri. |
Test |
Test connection to your bulb by flashing it. |
Turn off |
Force turning off your connected bulb. |
Sleep Phaser (disconnected) |
Tap this to connect to your Sleep Phaser. |
Smartlight |
Use your connected Sleep Phaser as a smartlight. Sleep Phaser doesn’t care about the topmost "Use smartlight" setting in this category. |
Sleep tracking |
Use your connected Sleep Phaser’s PIR sensor as a sensor for sleep tracking. |
Start automatically |
Start tracking automatically when you start charging your phone while your Sleep Phaser is in Bluetooth range.
For complete manual for Sleep Phaser, see Sleep Phaser.
Use Sleep Mask |
Enable to use your Sleep Mask as a smartlight. |
4. Guide
4.1. How to setup sunrise alarm (sunrise-like wakeup) ?
Enable Settings → Smartlight → Use smartlight
Select your smartlight:
Use phone’s screen as a smartlight: Enable Smartlight → Use screen light
Use a smartbulb as a smartlight: Connect using Smartlight → Philips HUE, IKEA Trådfri (disconnected)
Use Sleep Phaser as a smartlight: Connect using Smartlight → Sleep Phaser (disconnected) and enable Smartlight right under it.
Use cable-type Sleep Mask as a smartlight: Connect using Smartlight → Use Sleep Mask.
After you’ve done the above steps to connect and enable the smartlight of your choice, all of your alarms will turn on the smartlight when they start ringing. Now, to have a truly sunrise wakeup, you probably want the smartlight to turn on before the alarm rings.
To set that up, head to Settings → Alarms → Alarm sound start and set it to some period. At the time of the alarm, only the smartlight will turn on at the lowest brightness and gradually brighten up until the set period passes. Then the alarm starts ringing.
Without the delayed sound start, you can control the speed of sun-rise effect by changing the period of Gentle volume increase. The longer the period is, the longer it takes to get from dark to full light.
